This article will help you connect your Philips Smart TV to your wireless network using a wireless or wired connection.
Note: If you're using a wired connection, connect an Ethernet cable from your WiFi router to the Ethernet port on the back of your Philips Smart TV.
For a wireless connection, do the following:
  1. Ensure that your WiFi and TV are turned on.
  2. Press the Home button on your Philips TV remote control.
  3. Use the arrow keys to highlight Setup and then press OK.
  4. Select Connect to network and then choose Wireless or Wired.
  5. Use the arrow keys to highlight one of the following connection options:
  • WPS: If your In-home WiFi Router has WiFi protected setup.
  • Scan: Manually locate your WiFi network name.
  1. Press OK and then follow the on-screen prompts to connect to your In-home WiFi network.
  2. If necessary, enter your WiFi network Key (password).
  3. Once the TV is successfully connected to your home network, press OK.
