Download Manual
URC 1160
Programming Codes:
TV:
Audio Devices:
Setup by Code Search
Before setting up the remote:
Turn on the TV you wish to program the remote to.
Follow the instructions below to set up the remote to control the specific device you select.
  1. Simultaneously press and hold the MENU and OK keys on the remote until the INPUT key blinks twice.
  2. Enter the first code listed for your brand. The INPUT key will blink twice to confirm once complete.
  3. Test volume and power functions. If the device responds as expected, setup is complete. If not, repeat this process using the next code listed for your brand.
Setup Using Most Popular Brands
  2. Press and release the TV POWER KEY once.
  3. Find your TV brand in the table below and note the digit that relates to your TV brand. Press and hold down the digit key.
  4. Release the digit key when the TV turns off. Setup is complete.
Digit TV
1 Insignia/Dynex
2 LG/Zenith
3 Mitsubishi
4 Panasonic
5 Philips/Magnavox
6 Samsung
7 Sharp
8 Sony
9 Toshiba
0 Vizio
