Download Manual
1060BC2/1060BC3
Programming Codes:
TV:
Audio Devices:
Pairing Your Remote to Your Spectrum Receiver Using RF
If you have a Spectrum 100 or Spectrum 200 receiver, you can program your remote with radio frequencies (RF) to work with a specific receiver. This will allow you more freedom to control your receiver, since it doesn't require line of sight.
When you launch the Spectrum Guide, you'll be prompted to pair your remote with your receiver using radio frequencies:
  1. Press and hold the Options button on your remote until the connection is complete.
RF Pair One
  1. The Spectrum Guide will let you know when it's connected:
RF Pair One
You can also set up the RF pairing in your Spectrum Guide:
  1. Navigate to Settings & Support > Support and select Remote Control.
RF Pair One
  1. Choose RF Pair New Remote.
RF Pair Step 2
  1. Select RF Pair Remote.
RF Pair Step 3
  1. Your remote will now be paired with that specific receiver.
  2. If these steps don't work, you can use the instructions and codes above to pair your remote with your receiver using infrared (IR).
Pairing Your Remote With Your TV or Audio Device
Using the Spectrum Guide
Note: To use the Spectrum Guide to pair your remote with your TV or audio device, the remote must first be RF paired to your receiver.
Once you've paired your remote with your receiver, it may automatically detect your device's brand and guide you through the connection process. If your receiver can't automatically connect to your device, you can select your brand manually:
  1. Select Connect to TV or Connect to Audio.
TV Pair Step 1
  1. Use the arrow buttons to find your device's brand and press OK.
    • Note: If your device's brand isn't on the list of common brands, you can choose View All and browse the list of brands alphabetically.
TV Pair Step 2
  1. Follow the on-screen instructions to complete the connection process.
TV Pair Step 3
Unpair/Reset Your Remote
If you'd like to unpair your remote:
  1. Press and hold the Menu button and down arrow simultaneously on your remote control.
  2. Next, press 9 8 7.
If you'd like to reset your remote back to its factory settings:
  1. Press and hold the Menu and OK button simultaneously on your remote control.
  2. Next, press 9 8 1.
Note: Resetting your remote unpairs it from all devices and clears any programmed device codes.
