View more support videos for the new Spectrum Guide.
View or download a Quick Reference Guide for new Spectrum Guide settings.
Not your guide? Find out which guide you have.
 Top Parental Controls Topics
Parental Controls
Parental Controls
Turn Parental Controls On/Off
The first time you turn on Parental Controls, you will be asked to create a four-digit PIN. If you forget your Parental Controls PIN and need to have it reset, please call us at (833) 267-6094.
To turn Parental Controls on or off:
  1. Press the Menu button on your remote, scroll to Settings & Support using the arrow buttons and then press OK/Select.
  2. Using the arrow buttons, scroll down to Parental Controls and then press OK/Select.
  3. Press the right arrow to scroll over to Parental Controls Settings and then press OK/Select.
  4. Highlight Turn On/Off Parental Controls using the arrow buttons and then press OK/Select.
  5. Enter or create your four-digit PIN and then press OK/Select.
  6. Use the arrow buttons to select On or Off and then press OK/Select.
  7. Highlight Save and then press OK/Select to confirm your changes.
Create or Change Your PIN
To set or change your PIN:
  4. Highlight the Set Parental Controls PIN using the arrow buttons and then press OK/Select.
    • To set a PIN: Enter a 4-digit number that is easy to remember but isn't easily guessed by members of your household. Confirm your PIN by entering the number again.
    • To change a PIN: Enter your existing PIN and then follow the prompts to create a new PIN.
  5. Highlight Save and then press OK/Select to confirm your changes.
Create PIN
Forgot PIN
Hide Adult Content and Require PIN to access
You can turn on the Hide Adult Content setting if you want to prevent adult content titles from displaying in the Spectrum Guide. When this setting is enabled, you'll be prompted to enter your PIN if adult content is accessed using direct channel number input.
Note: Turning ON the Hide Adult Content setting will hide adult titles in the guide whether Parental Controls are ON or OFF. It's important to remember that Parental Controls must be turned ON to require your PIN if adult content is accessed using direct channel number input.
To turn Hide Adult Content on/off and require a PIN to access:
  4. Highlight Hide Adult Content using the arrow buttons and then press OK/Select.
  5. Enter or create your PIN, then press OK/Select.
  6. Use the arrow buttons to select On (enable) or Off (disable) and then press OK/Select.
Restrict by Rating
You can turn on the Rating Restrictions setting to block programs with a specific rating. When this setting is enabled, you'll be prompted to enter your PIN when attempting to access programming with that rating or above, as well as programming that is unrated. Learn more about   program ratings.
To restrict programming by rating:
  4. Highlight Rating Restrictions using the arrow buttons and then press OK/Select.
  5. Enter or create your PIN and then press OK/Select.
  6. Use the arrow buttons to select the ratings you want to restrict, then press OK/Select. When you choose a rating, all higher ratings in that category will automatically be restricted. Note: You must set restrictions for movie and TV content separately.
Restrict by Channel
You can turn on the Channel Restrictions setting to restrict access to specific networks. When this setting is enabled, you'll be prompted to enter your PIN when attempting to access blocked channels.
To restrict specific channels:
  4. Highlight Channel Restrictions using the arrow buttons and then press OK/Select.
  6. Use the arrow buttons to select the specific channels you want to restrict and then press OK/Select.
Note: When you set Parental Controls to block certain channels, you may see a lock icon on those channels. If you don't see the icon, the channels will still require a PIN to access.
Restrict by Content Type
You can set up Content Filters to restrict programming with violent or inappropriate content. When this setting is enabled, you'll be prompted to enter your PIN when attempting to access programming that contains specific themes or content you've restricted.
To restrict specific content:
  4. Highlight Content Filters using the arrow buttons and then press OK/Select.
  6. Use the arrow buttons to select the content you want to restrict and then press OK/Select.
Restrict by Time/Day
You can use the Time/Day Restrictions settings to control when members of your household can view programming. When this setting is enabled, you'll be prompted to enter your PIN before watching TV or movies during a specific time frame. Repeat the steps below to set up to 10 separate restrictions.
To set a Time/Day Restriction:
  4. Highlight Time/Day Restrictions using the arrow buttons and then press OK/Select.
  6. Use the arrow buttons to select Add Restriction and then press OK/Select.
  7. Highlight and select the days you want to restrict, press OK/Select and then use the number and arrow buttons to select the specific time. To switch between AM and PM, highlight the AM/PM field and press OK/Select.
  8. Highlight Save and then press OK/Select to confirm your changes.
To edit a Time/Day Restriction:
  6. Use the arrow buttons to highlight one of your set restrictions and then press OK/Select.
  7. Make your desired changes and then press OK/Select.
To delete a Time/Day Restriction:
  6. Use the arrow buttons to highlight the delete icon next to the restriction you want to remove and then press OK/Select.
  8. Highlight Remove and then press OK/Select to remove the restriction.
Purchase Controls
The first time you turn on Purchase Controls, you will be asked to set a four-digit PIN. If you forget your Purchase Controls PIN and need to have it reset, please call us at (833) 267-6094.
To create or change your PIN:
  3. Press the right arrow to scroll over to Purchase Controls and then press OK/Select.
  4. Using the arrow buttons, highlight Set Purchase Controls PIN and then press OK/Select.
Create Purchase PIN
Forgot PIN
Turn Purchase Controls On/Off
To turn Purchase Controls on or off:
  4. Using the arrow buttons, highlight Turn On/Off Purchase Controls and then press OK/Select.
Set Purchase Limits
You can set a purchase limit to only allow purchases and rentals with a cost below your set limit. Purchases exceeding your set purchase limit will require you to enter your Purchase Controls PIN.
To set the Purchase Limit:
  4. Using the arrow buttons, highlight Set Purchase Limits and then press OK/Select.
  5. Use the number keypad on your remote to enter the purchase limit.
  6. Highlight Save using the arrow buttons and then press OK/Select to confirm your purchase limit.
Set Purchase Limits
On Demand Lock
You have the choice to allow or restrict access to On Demand programming with On Demand Lock. When this feature is enabled, access to any On Demand programming will require you to enter your PIN.
Note: If you don't know your PIN or if you haven't created one yet, you can try entering 0000 or 1234 as the default.
  3. Press the right arrow to scroll over to On Demand Lock and then press OK/Select.
  4. Using the arrow buttons, highlight Set On Demand PIN and then press OK/Select.
Create On Demand PIN
Forgot PIN
If you don't know your PIN or if you haven't created one yet, you can try entering 0000 or 1234 as the default. If you forget your On Demand PIN and need to have it reset, please call us at (833) 267-6094.
Turn On Demand Lock On/Off
The first time you turn on On Demand Lock, you will be asked to set a four-digit PIN. If you don't know your PIN or if you haven't created one yet, you can try entering 0000 or 1234 as the default. If you forget your On Demand Lock PIN and need to have it reset, please call us at (833) 267-6094.
To turn On Demand Lock On/Off:
  4. Using the arrow buttons, highlight Turn On/Off On Demand Lock and then press OK/Select.
To learn more about the new Spectrum Guide, please visit the new Spectrum Guide support page.
Frequently Asked Questions
How do I change settings in the new Spectrum Guide?
Changesettings
See more Frequently Asked Questions
What if I'm missing channels?
If you are missing channels, it is possible your Guide settings need to be adjusted. You can adjust the filters by using your remote control.
You can also check the Parental Controls by going to Settings & Support > Parental Controls.
Otherwise, you can follow the Troubleshooting steps here.
What is an On Demand PIN and how do I change it?
On Demand Lock lets you restrict or allow access to On Demand programming by setting a PIN. If you don't know your PIN or if you haven't created one yet, you can try entering 0000 or 1234 as the default. Learn more about On Demand Lock.
