View more support videos for the new Spectrum Guide.
Not your guide? Find out which guide you have.
Instead of scrolling through the guide to find your most-watched channels, you can mark them as a Favorite and filter the guide to view only what's playing on your those selected channels. Use the quick links below to navigate to the section of your choice.
Manage Favorites
To add or delete Favorites in the new Spectrum Guide:
  1. Press the Guide button on your remote control.
  2. Scroll left and highlight the channel number, then press OK/Select.
  3. Use the arrow buttons to highlight Favorite or Unfavorite and press OK/Select.
favorites button under channel description
Note: A red heart icon will appear next to the channel in the guide when it's marked as a Favorite.
Add and Delete Favorite Channels in Settings & Support
You can also manage your Favorites through Settings & Support:
  1. Press the Menu button on your remote control.
  2. Use the arrow buttons to scroll to Settings & Support and then press OK/Select.
  3. Navigate to Preferences and then select Favorites.
  4. Using the arrow buttons, highlight the box next to a network of your choice and then press OK/Select to add or remove it as a Favorite.
  5. Use the arrow buttons to scroll over to Save and then press OK/Select.
View Favorites
You can easily access your Favorites by pressing the FAV button on your remote while watching live TV or browsing the Guide. If you have more than one favorite saved, press the FAV button until you reach the channel you want to watch.
You can also filter the guide to only show what's playing on your favorite channels:
  2. Use the arrow buttons to scroll to Guide and then press OK/Select.
  3. Press the B button on your remote to access filters.
  4. Use the arrow buttons to highlight Favorites and then press OK/Select. A red checkmark will appear in the box.
  5. Use the arrow buttons to choose to sort channels alphabetically or by channel number and then press OK/Select.
  6. Highlight Filter and then press OK/Select to save your changes and return to the Guide.
Note: To turn off filter by favorites, repeat the steps and choose the desired filter or select All.
Favorites filter in the Guide options
To learn more, visit our new Spectrum Guide support page.
