Settings
Not your guide? Find out which guide you have.
Looking for Descriptive Video Service (DVS) settings?
Descriptive Video Services (DVS) is a secondary audio track that narrates natural pauses in dialogue and can describe actions, costumes, facial expressions, settings and scene changes. Learn more.
View or download a Quick Reference Guide for new Spectrum Guide settings.
Turn Closed Captioning On/Off
Closed captioning displays the audio portion of a program as text on your TV screen.
To turn Closed Captioning On or Off:
  1. Press the Menu button on your remote to open the Spectrum Guide Main Menu.
  2. Use the arrow buttons to scroll to Settings & Support and then press OK/Select.
  3. Select Accessibility, scroll right to highlight Closed Captioning, and then press OK/Select.
  4. Use the arrow buttons to select On (enable) or Off (disable) and then press OK/Select.
  5. Highlight Save and then press OK/Select to save your changes.
Note: To quickly turn Closed Captioning on or off, press the A button on your remote control while viewing full-screen programming and then press the 1 button.
Presentation Settings
You can adjust how Closed Captioning text appears on screen in Presentation Settings:
  3. Select Accessibility, scroll right to highlight Closed Captioning Settings, and then press OK/Select.
  4. Highlight Presentation, then press OK/Select.
  5. Use the arrow buttons to select one of the following display settings:
    • Pop-On: Text appears as complete sentences, which can be followed with additional captions.
    • Roll-Up: Text scrolls up to make way for a new line and the top line is erased.
    • Paint-On: Text appears from left to right, one line at a time.
  6. Highlight Save and then press OK/Select to confirm your changes.
Text Settings
You can adjust the color, transparency, size and font of your Closed Captioning in Text Settings:
  4. Scroll right to highlight Text Settings, then press OK/Select.
  5. Use the arrow buttons to select the font setting you want to adjust and then press OK/Select:
    • Color: Select a color for the closed captioning text that will appear on your TV screen.
    • Transparency: Select the degree to which you can see through the text, either Opaque or Semi-transparent.
    • Size: Choose a small, medium, or large font.
    • Font: Select which font style you prefer for the closed captioning text.
    • Character Edge: Choose hoe you want the edges of the characters to appear in closed captioning text.
  6. Highlight Save and press OK/Select to confirm your changes.
Background Settings
You can change the background on which your Closed Captioning text appears in Background Settings:
  4. Scroll right to highlight Background Settings, then press OK/Select.
  5. Use the arrow buttons to select the background setting you want to adjust and then press OK/Select:
    • Color: Select a background color that is different than the text color.
    • Transparency: Select the degree to which you can see through the background.
Window Settings
To select a color and transparency setting for the window surrounding the Closed Captioning text in Window Settings:
  4. Scroll right to highlight Window Settings, then press OK/Select.
  5. Use the arrow buttons to choose from the following settings and then press OK/Select:
    • Color: Select a color for the window surrounding the closed captioning text.
    • Transparency: Select the degree to which you can see through the window.
Change the Default Language
  4. Scroll right to highlight Language, then press OK/Select.
  5. Use the arrow buttons to select a language and then press OK/Select:
    • Primary Language: The language the program is broadcast in. This is usually English, but it may be Spanish, French or another language for foreign language packages.
    • Secondary Language: Matches the SAP (secondary audio stream) that a broadcaster may choose to transmit for the program.
    • CC3, CC4, CC5, CC6: Additional closed captioning tracks that may be provided by the programmer, including Descriptive Video Services (DVS).
Closed Captioning Type
You can choose to see a full transcription of the program's audio as text or a simplified version in Closed Captioning Type settings:
  4. Scroll right to highlight Closed Captioning Type, then press OK/Select.
  5. Use the arrow buttons to select the type of closed captioning you want and then press OK/Select:
    • Standard Captioning: Displays the audio portion of a television program as text.
    • Easy Reader: Offers simplified Closed Captioning for viewers with a limited vocabulary (e.g. children).
  6. Highlight Save and then press OK/Select to save your changes.
Frequently Asked Questions
How do I change settings in the new Spectrum Guide?
Changesettings
See more Frequently Asked Questions
To learn more about the new Spectrum Guide, please visit our new Spectrum Guide support page.
