Download Manual
Polaris URC 1090
Programming Codes:
Select the manufacturer of your device from the list. The codes will appear beside the list boxes.
TV:
DVD Player:
Audio:
Video Accessory:
Setup (Programming Device Control)
Follow the instructions below to set up the remote to control the specific device you select.
  1. Press the TV POWER key.
  2. Press and hold SETUP until the TV POWER key blinks twice then release.
  3. Enter the first TV code for your brand from the list in your manual or from the lookup tool above.
  4. Press the TV POWER key to test TV control. If the TV turns off, setup is complete.
  5. If the TV does not turn off, repeat Step 3 using the next code for your TV brand.
Setup Control Using Code Search
  3. Type 9-9-1 on the number keys.
  4. Press CH+ repeatedly until the TV turns ON or OFF.
  5. Press SETUP key to save working code.
Blinking Back the Code
  1. Press the device (TV, VCR, CABLE, etc.) button then release.
  2. Press and hold the SETUP button until the red LED flashes twice, then release.
  3. Press 9 - 9 - 0.
  4. Press 1, count the number of blinks (1st digit).
  5. Press 2, count the number of blinks (2nd digit).
  6. Press 3, count the number of blinks (3rd digit).
  7. Press 4, count the number of blinks (4th digit).
If the remote DOES NOT blink it means the number is 0. This is your 4-digit setup code.
Volume Lock
  1. Press and hold the SETUP button until the red LED flashes twice, then release.
  2. Press 9 - 9 - 3.
  3. Press the device button from where you want volume to be controlled.
