Download Manual
UR4-EXP CHLA
Programming Codes:
TV:
DVD Player:
Blu-Ray Player:
Digital Receiver:
VCR:
Three-Digit Code Programming Method
The remote control can be programmed by entering in a three-digit code number that corresponds to a particular brand of equipment.
  1. Turn on the equipment you wish to program.
  2. Press the SELECT button and MUTE button simultaneously for 3 seconds. The device LEDs blink in sequence (TV-VCR-AUX-CBL-TV).
  3. Release the buttons when the desired device button is blinking (the device LED will remain lit).
  4. The device LED will stay lit for 20 seconds. The next step must be entered while the LED is on.
  5. Point the remote control toward the equipment and enter the three-digit code number assigned to your brand from the code tables.
    • The equipment will turn off when the correct three-digit code number has been entered. You can verify that you've selected the correct code by pressing the POWER button. The equipment should turn on or turn off.
      If more than one three-digit number is listed for your brand, try one code number at a time until your equipment turns off.
  6. Store the three-digit code number by pressing the SELECT button. The device LED will blink twice to confirm that the code has been stored.
    Try all the functions on the remote control. If any of the functions don't work as they should, repeat from Step 2 using the next code from the same brand list.
Auto-Search Method
If the three-digit code numbers assigned to your brand don't work, or if your brand isn't listed above, you can use the auto-search method to find the correct three-digit code number for your equipment by the following steps:
  3. Release the buttons when the desired device button is blinking (the device LED will then remain lit).
    • The device LED will stay lit for 20 seconds. The next step must be entered while LED is on.
  4. Press the and hold the CH+ or CH- button. The remote will emit a series of power on/off commands. Release the CH+ or CH- button as soon as the equipment turns off.
    • You can verify that you selected the correct code by pressing the POWER button. The equipment should either turn on or turn off.
  5. Press the SELECT button to store the code. The device LED will blink twice to confirm that the code has been stored.
Find the Three Digit Code Number That was Stored in the Device
  1. Press the SELECT button and MUTE button simultaneously for 3 seconds. The device LEDs blink in sequence (TV-VCR-AUX-CBL-TV).
  2. Release the buttons when the desired device button is blinking (the device LED will then remain lit).
    • The device LED will stay lit for 20 seconds. The next step must be entered while the LED is on.
  3. Press the INFO button. The device LED will blink number of times indicating the number of each digit of the code number. Each digit is separated by a 1-second interval of the LED turning off.
  4. For example, a sequence of one blink, three blinks and eight blinks would indicate the code 138. Ten blinks indicate the digit 0.
