Download Manual
UR4-EXP CHLA
Programming Codes:
TV:
DVD Player:
Blu-Ray Player:
Digital Receiver:
VCR:
Three-Digit Code Programming Method
The remote control can be programmed by entering in a three-digit code number that corresponds to a particular brand of electronic device.
  1. Turn on the device you wish to program.
  2. Press the SELECT button and MUTE button simultaneously for 3 seconds. The device LEDs blink in sequence (TV-VCR-AUX-CBL-TV).
  3. Release the buttons when the desired device button is blinking. The device LED will then remain lit for 20 seconds. The next step must be completed while the LED is on.
  4. Point the remote control at your device and enter the three-digit number that corresponds to your device's brand. If there is more than one three-digit number listed for your brand, try one code number at a time until your equipment turns off.
    • The equipment will turn off when the correct three-digit code number has been entered. You can verify that you selected the correct code by pressing the POWER button. The equipment should turn on or turn off.
  5. Store the three-digit code number by pressing the SELECT button. The device LED will blink twice to confirm that the code has been stored.
    Try all the functions on the remote control. If any of the functions do not work as they should, repeat from Step 2 using the next three digit code number from the same brand list.
Auto-Search Method
If the three-digit code numbers assigned to your brand do not turn off your equipment or the code tables do not list your brand, you can use the auto-search method to find the correct three-digit code number for your equipment by the following steps:
  1. Turn on the equipment you wish to program (TV, VCR, DVD or AUX).
  2. Press the SELECT and MUTE buttons simultaneously for 3 seconds. The device LEDs blink in sequence (TV-VCR-AUX-CBL-TV).
  3. Release the buttons when the desired device button is blinking. The device LED will then remain lit for 20 seconds. The next step must be entered while LED is on.
  4. Press the CH+ or CH- button. The remote will emit a series of power on/off commands. Release the CH+ or CH- button as soon as the equipment turns off.
    • You can verify that you selected the correct code by pressing the POWER button. The equipment should either turn on or turn off.
  5. Press the SELECT button to store the code. The device LED will blink twice to confirm that the code has been stored.
Find the Three Digit Code Number That was Stored in the Device
  1. Press the SELECT and MUTE buttons simultaneously for 3 seconds. The device LEDs blink in sequence (TV-VCR-AUX-CBL-TV).
  2. Release the buttons when the desired device button is blinking. The device LED will then remain lit for 20 seconds. The next step must be entered while the LED is on.
  3. Press the INFO button. The device LED will blink number of times indicating the number of each digit of the code number. Each digit is separated by a 1-second interval of the LED being turned off. For example: One blink, three blinks and eight blinks separated by 1-second intervals indicate the code number 138.
