Download Manual
UE Atlas XL
Programming Codes:
TV:
DVD Player:
Blu-Ray Player:
Digital Receiver:
VCR:
Programming Device Control
The Atlas XL Universal Remote Control is pre-programmed to operate the cable converter provided by your cable service provider, an RCA TV, an RCA VCR, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps:
To control a DVD player, program the VCR key. To control a DVR, program the DVR key. To control a stereo amplifier or receiver, program the AUD key. For TV/VCR combo control, skip this section and perform the Programming TV/VCR Combo Control instructions below.
  1. Turn on a device and, if applicable, insert video media, (e.g. a DVD).
  2. On the remote control, press a device key once (e.g. AUD, VCR, or TV). Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice.
  4. Note: If the selected mode key emits a long blink, the entry is invalid. Repeat steps 2 through 3 and try entering the same code again.
  5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 through 3, trying each code for your brand until you find one that works. If it still does not respond, try searching for the code (see Searching for Your Code below). If the device does not have a POWER key, press the (Play) key.
  6. Repeat steps 1 through 4 for each device you want the remote control to control. For future reference write down each working device code.
  1. Turn on your TV/VCR combo and insert a video cassette.
  2. On the remote control, press VCR once. Press and hold SETUP until the VCR key blinks twice, then release SETUP.
  3. Use the Setup Codes for TV/VCR combos to locate the brand name and then enter the first four-digit code for your TV/VCR Combo. If you perform this procedure correctly, the VCR key will blink twice.
    Note: If the VCR key didn't blink twice after entering the code's last digit, then repeat steps 2 through 3 and try entering the same code again. If you've located a TV/VCR setup code that works your TV/VCR Combo but a separate TV code is also listed, you'll need to program this code into the remote control to access volume control (see Programming Device Control).
  4. Aim the remote control at your TV/VCR combo and press POWER once. The device should turn off. If it does not respond, repeat steps 2 and 3, trying each code listed for your brand until you find one that works. If it still does not respond, try searching for the code (see Searching For Your Code).
  5. For future reference, write down each working device code.
  1. Turn on your TV.
  2. On the remote control, press TV once. Then press and hold SETUP until the TV key blinks twice, then release SETUP.
  3. Enter 9 - 9 - 1. The TV key will blink twice.
  4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off. In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
  5. Press SETUP once to lock in the code. The TV key will blink twice.
  6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate key (i.e. AUD or VCR) for the Audio or VCR device you are searching for.
Checking the Codes
If you have set up the Atlas XL Universal Remote Control using the Searching for Your Code procedure, you may need to find out which four-digit code is operating your equipment. For example, to find out which code is operating your TV:
  1. On the remote control, press TV once. Then press and hold SETUP until the TV key blinks twice, then release SETUP.
  2. Enter 9 - 9 - 0. The TV key will blink twice.
  3. To view the code for the first digit, press 1 once. Wait three seconds and count the number of times the TV key blinks (e.g, 3 blinks = and write down the number. If a code digit is '0', the selected mode key will not blink.
  4. Repeat step 4 three more times for remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit.
  5. To check for other device codes, repeat steps 1 through 5, but substitute the appropriate key (i.e, AUD or VCR) for the Audio or VCR device you are checking. Write down the codes.
Using the Master Power Key
The Atlas XL Universal Remote Control has a unique feature that allows you to sequentially turn on or off up to four of your home entertainment devices with a single key press. Master Power requires programming and only works in the CBL mode. If it is not programmed, only the cable converter will turn on or off. In any other mode, pressing Master Power once will turn on or off the selected device.
To Program the Master Power Key:
  1. On the remote control, press and hold SETUP until the last-selected device key blinks twice, then release SETUP.
  2. Enter 9 - 9 - 5.The last-selected device key will blink twice. Then press POWER once.
  3. For the first device you want in the power on sequence, press a device key (e.g. TV) once and then press POWER once.
  4. Repeat step 3 up to three more times to add a second, third and fourth device, as desired.
  5. To save the settings and exit the program, press CBL once. Next, press and hold SETUP until the CBL key blinks twice, then release SETUP.
To Operate the Master Power Key:
  1. After programming, point the remote control at the devices. Press CBL once.
  2. Press MASTER POWER once to sequentially turn on or off all home entertainment devices.
You will see the devices turn on or off according to the programmed sequence.
To Clear The Master Power Key:
  1. Perform steps 1 and 2 in the first section above, To Program The Master Power Key.
  2. To clear the settings and exit the program, press and hold SETUP until the CBL key blinks twice, then release SETUP.
Programming Channel Control Lock
By default, the remote control's channel-control capabilities are locked to the cable converter. The affected keys are 0~9, CH+, CH-, ENTER and LAST. This will guarantee that you do not inadvertently change a channel on your TV or VCR. However, you can deactivate this feature to allow full access to these keys in the TV and VCR modes.
Note: This feature does not affect the AUD mode.
To Deactivate Channel Control Lock:
  1. On the remote control, press CBL once. Then press and hold SETUP until the CBL key blinks twice, then release SETUP.
  2. Enter 9 -7- 3.The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
  4. Now, the remote control will provide TV and VCR channel control capabilities while in the TV or VCR mode.
To Reactivate Channel Control Lock:
  3. Press CH+ once. The CBL key will blink twice.
Now, regardless of what mode you select (i.e. TV or VCR), only the channel control capability of your cable converter will be accessible.
