Download Manual
UR4U-MDVR-CHD2
Programming Codes:
TV:
DVD Player:
Blu-Ray Player:
Digital Receiver:
VCR:
Programming Device Control
The Atlas DVR/PVR 5-Device Universal Remote Control is pre-programmed to operate the Scientific Atlanta/Cisco cable box, an RCA TV, a Toshiba DVD player, an RCA VCR (as an AUX device), and a Pioneer audio receiver. If you have another brand of cable converter or a satellite receiver you?d like to control, you'll first need to unlock the cable ID Lock before changing the converter code.
  1. Turn on a device and, if applicable, insert video media, (e.g. cassette or disc).
  2. On the remote control, press a device key once (i.e. AUX, DVD, AUD, TV, or CBL); it will blink once. Then press and hold SETUP until the selected mode key blinks twice, then release SETUP.
    Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice.
    Note: If the selected mode key emits a long blink, the entry is invalid. Repeat steps 2 through 3 and try entering the same code again.
  3. Aim the remote control at the device and press PWR once. The device should turn off. If it does not, repeat steps 2 through 3, trying each code for your brand until you find one that works. If it still does not respond, try searching for the code.
    If the device does not have a POWER key, press the Play key.
  4. Repeat steps 1 through 4 for each device you want the remote control to operate.
Programming TV/VCR Combo Control
  1. Turn on your TV/VCR combo and insert a video cassette.
  2. On the remote control, press AUX once; it will blink once. Then press and hold SETUP until the AUX key blinks twice, then release SETUP.
  3. Use the setup codes for TV/VCR combos to locate the brand name and then enter the first four-digit code for your TV/VCR combo. If you perform this procedure correctly, the AUX key will blink twice.
    If the AUX key did not blink twice after entering the code's last digit, then repeat steps 2 through 3 and try entering the same code again. If you've located a TV/VCR setup code that works for your TV/VCR combo and a separate TV code is also listed, you'll need to program this code into the remote control to access volume control.
  4. Aim the remote control at your TV/VCR combo and press PWR once. The device should turn off. If it does not respond, repeat steps 2 through 3, trying each code listed for your brand until you find one that works. If it still does not respond, try searching for the code.
Searching for Your Code
If your home entertainment device does not respond to the Atlas DVR/PVR 5-Device Universal Remote Control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, to search for a code for your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once; it will blink once. Then press and hold SETUP until the TV key blinks twice, then release SETUP.
  3. Enter 9 - 9 - 1. The TV key will blink twice.
  4. Aim the remote control at the TV and press PWR once.
  5. Press CH+ one or more times and stop when the TV turns off.
    In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
  6. Press SETUP once to lock in the code. The TV key will blink twice.
  7. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate key (e.g. AUX, DVD, AUD, or CBL) for the device you are searching for.
Checking the Codes
If you have set up the Atlas DVR/PVR 5-Device Universal Remote Control using the "Searching For Your Code" procedure, you may need to find out which four-digit code is operating your equipment.
For example, to find out which code is operating your TV:
  1. On the remote control, press TV once; it will blink once. Then press and hold SETUP until the TV key blinks twice, then release SETUP.
  2. Enter 9 - 9 - 0. The TV key will blink twice.
  3. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks = 3).
    Note: If a code digit is '0', the selected mode key will not blink.
  4. Repeat step 3 three more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit.
  5. To check for other device codes, repeat steps 1 through 4, but substitute the appropriate key (e.g. AUX, DVD, AUD, or CBL) for the device you are checking.
