Download Manual
UE Atlas 4
Programming Codes:
TV:
DVD Player:
Digital Receiver:
VCR:
Programming ID Lock
  1. The Atlas Universal Remote Control is preprogrammed and locked at the factory to operate a Scientific Atlanta cable converter. However, if you have another brand or model of cable converter and interactive service that you would like to control, then you'll need to perform the following steps to unlock the cable ID Lock, enter in a new manufacturer's code, and lock the ID Lock again.
  2. Turn on the cable converter.
  3. On the remote control, press CBL once. Then press and hold Setup until the CBL key blinks twice, then release Setup.
  4. Enter 9 - 8 - 2. The CBL key will blink four times.
  5. Perform the instructions in Programming Device Control to program device control for the desired cable converter and interactive service. Upon completion, perform the remaining steps (6 and 7) to lock the ID lock.
  6. On the remote control, press CBL once. Then press and hold Setup until the CBL key blinks twice, then release Setup.
  7. Enter 9 - 8 - 2. The CBL key will blink twice.
Programming Device
  1. Turn on a device and, if applicable, insert video medium (e.g. cassette or disc).
  2. On the remote control, press a device key once (e.g. AUD, VCR, TV, or CBL). Press and hold Setup until the selected mode key blinks twice, then release Setup.
  3. Use the manufacturer's codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice.
    Note: If the selected mode key emits a long blink, the code is invalid. Repeat steps 2 through 3 and try entering the same code again.
  4. Aim the remote control at the device and press Power once. The device should turn off. If it does not, repeat steps 2 and 3, trying each code for your brand until you find one that works. If it still does not work, try searching for the code.
    Note: If the device does not have a Power key, press the Play key.
  5. Repeat steps 1 through 4 for each device you want the remote control to control. For future reference, write down each working device code.
Programming TV/VCR Combo
  1. Turn on your TV/VCR combo and insert a video cassette.
  2. On the remote control, press VCR once. Press and hold Setup until the VCR key blinks twice, then release Setup.
  3. Use the Setup Codes For TV/VCR Combos to locate the brand name and then enter the first four-digit code for your TV/VCR Combo. If you perform this procedure correctly, the VCR key will blink twice.
    Note: If the VCR key did not blink twice after entering the code's last digit, then repeat steps 2 through 3 and try entering the same code again. If you've located a TV/VCR setup code that works your TV/VCR Combo and a separate TV code is also listed, you'll need to program this code into the remote control to access volume control (see Programming Device Control).
  4. Aim the remote control at your TV/VCR combo and press Power once. The device should turn off. If it does not respond, repeat steps 2 and 3 (starting on the previous page), trying each code listed for your brand until you find one that works. If it still does not work, try searching for the code (see Searching For Your Code).
  5. For future reference, write down each working device code.
Searching for Your Code
  1. Turn on your TV.
  2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
  3. Enter 9 - 9 - 1. The TV key will blink twice.
  4. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off.
    Note: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
  5. Press Setup once to lock in the code.
  6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate key (e.g. AUD, VCR, or CBL) for the (Audio, VCR, or Cable) device you are searching for.
Checking the Codes
  1. If you have set up the Atlas universal remote control using the Searching For Your Code procedure, you may need to find out which four-digit code is operating your equipment. For example, to find out which code is operating your TV:
  3. Enter 9 - 9 - 0. The TV key will blink twice.
  4. To view the code for the first digit, press 1 once. Wait three seconds and count the number of times the TV key blinks (e.g., 3 blinks = 3) and write down the number in the far-left TV Code box.
    Note: If a code digit is "0," the selected mode key will not blink.
  5. Repeat step 4 three more times for remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit.
  6. To check for other device codes, repeat steps 1 through 5, but substitute the appropriate key (i.e., AUD, VCR, or CBL) for the (Audio, VCR, or Cable) device you are checking. Write down the codes.
