The following information will help you connect your Samsung Smart TV to your In-home WiFi.
Wireless Connection
  1. Press Menu on your Samsung remote and scroll to Network.
    highlight network in menu
  2. Select Wireless as the Network Type.
    Network type
  3. Select Network Setup.
    network setup
  4. Choose Select a Network.
    select network
  5. Select your Network Name.
    select_network_name
  6. Enter your WiFi password and press the Blue button on your Samsung remote.
    enter password
  7. Your Samsung TV will attempt to connect to your In-home WiFi.
    connecting to network
  8. When you are connected select OK.
    successful connection message
Wired Connection
  1. Connect one end of an Ethernet cable to the LAN port on your Samsung Smart TV.
    connection jacks
  2. Connect the other end of the Ethernet cable to an open LAN port on your WiFi router.
    press menu instruction
  2. Select Wired as the Network Type.
    set network to wired
  3. Select Network Test to verify connectivity.
    network test
  4. Your Samsung Smart TV should now be connected.
    connected message
